EXIF安裝請(qǐng)教
bamuyi
EXIF安裝請(qǐng)教
[root@AY130701215223445424Z ~]# cd /usr/local/src/php-5.2.17/ext
[root@AY130701215223445424Z ext]# cd exif/
[root@AY130701215223445424Z exif]# /www/wdlinux/apache_php-5.3.26/bin/phpize
Configuring for:
PHP Api Version: 20090626
Zend Module Api No: 20090626
Zend Extension Api No: 220090626
[root@AY130701215223445424Z exif]# ./configure --with-php-config=/www/wdlinux/apache_php-5.3.26/bin/php-config
checking for cc... cc
checking for icc... no
checking for suncc... no
checking for PHP prefix... /www/wdlinux/apache_php-5.3.26
checking for PHP includes... -I/www/wdlinux/apache_php-5.3.26/include/php -I/www/wdlinux/apache_php-5.3.26/include/php/main -I/www/wdlinux/apache_php-5.3.26/include/php/TSRM -I/www/wdlinux/apache_php-5.3.26/include/php/Zend -I/www/wdlinux/apache_php-5.3.26/include/php/ext -I/www/wdlinux/apache_php-5.3.26/include/php/ext/date/lib
checking for PHP extension directory... /www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626
checking for PHP installed headers prefix... /www/wdlinux/apache_php-5.3.26/include/php
checking for re2c... no
configure: WARNING: You will need re2c 0.13.4 or later if you want to regenerate PHP parsers.
checking for gawk... gawk
checking whether to enable EXIF (metadata from images) support... yes, shared
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking whether the cc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
creating libtool
config.status: config.h is unchanged
[root@AY130701215223445424Z exif]# make && make install
/bin/sh /usr/local/src/php-5.2.17/ext/exif/libtool --mode=install cp ./exif.la /usr/local/src/php-5.2.17/ext/exif/modules
cp ./.libs/exif.so /usr/local/src/php-5.2.17/ext/exif/modules/exif.so
cp ./.libs/exif.lai /usr/local/src/php-5.2.17/ext/exif/modules/exif.la
PATH="$PATH:/sbin" ldconfig -n /usr/local/src/php-5.2.17/ext/exif/modules
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the `LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the `LD_RUN_PATH' environment variable
during linking
- use the `-Wl,--rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
Build complete.
Installing shared extensions: /www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626/
Configure Command './configure' '--prefix=/www/wdlinux/apache_php-5.3.26' '--with-config-file-path=/www/wdlinux/apache_php-5.3.26/etc' '--with-mysql=/www/wdlinux/mysql' '--with-iconv=/usr' '--with-freetype-dir' '--with-jpeg-dir' '--with-png-dir' '--with-zlib' '--with-libxml-dir=/usr' '--enable-xml' '--disable-rpath' '--enable-discard-path' '--enable-inline-optimization' '--with-curl' '--enable-mbregex' '--enable-mbstring' '--with-mcrypt=/usr' '--with-gd' '--enable-gd-native-ttf' '--with-openssl' '--with-mhash' '--enable-ftp' '--enable-sockets' '--enable-zip' '--with-apxs2=/www/wdlinux/apache/bin/apxs'
為什么還是安裝不上,是不是哪里出現(xiàn)了問題?
PHP.INI
配置如下
; Directory in which the loadable extensions (modules) reside.
; http://php.net/extension-dir
extension_dir = "/www/wdlinux/apache_php-5.3.26/lib/php/extensions/no-debug-non-zts-20090626/"
; On windows:
extension_dir = "ext"
extension = "exif.so";
請(qǐng)求幫助
怎么5.3的環(huán)境,用5.2的源碼來編譯?
