標(biāo)題: [求助] 安裝之后 控制面板打不開 新手求助 [打印本頁]
作者: zhengrhd    時間: 2013-8-2 23:14     標(biāo)題: 安裝之后 控制面板打不開 新手求助
  1. To start mysqld at boot time you have to copy
  2. support-files/mysql.server to the right place for your system
  3. PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
  4. To do so, start the server, then issue the following commands:
  5. /www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root password 'new-password'
  6. /www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root -h AY130801212018195dc4Z password 'new-password'
  7. Alternatively you can run:
  8. /www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
  9. which will also give you the option of removing the test
  10. databases and anonymous user created by default. This is
  11. strongly recommended for production servers.
  12. See the manual for more instructions.
  13. You can start the MySQL daemon with:
  14. cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
  15. You can test the MySQL daemon with mysql-test-run.pl
  16. cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
  17. Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
  18. Starting MySQL. SUCCESS!
  19. Starting httpd: httpd: Syntax error on line 54 of /www/wdlinux/httpd-2.2.22/conf/httpd.conf: Cannot load /www/wdlinux/httpd-2.2.22/modules/libphp5.so into server: libmhash.so.2: cannot open shared object file: No such file or directory
  20. [FAILED]
  21. Starting nginx: [ OK ]
  22. Starting httpd: Syntax error on line 232 of /www/wdlinux/wdapache/conf/httpd.conf:
  23. Cannot load /www/wdlinux/wdapache/modules/libphp5.so into server: libpng12.so.0: cannot open shared object file: No such file or directory
  24. [FAILED]
  25. Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
  26. ============ lanmp_wdcp install OK ==============
  27. configuration ,lamp or lnmp,wdcp install is finshed
  28. visit http://ip
  29. wdcp visit http://ip:8080
  30. more infomation please visit [url=http://www.gps-cemuyi.cn
http://www.gps-cemuyi.cn[/code[/url]]
啊里云的服務(wù)器
作者: admin    時間: 2013-8-3 09:59
重起下系統(tǒng)
