標題: [求助] 求救,這是怎么了? [打印本頁]
作者: 270330940    時間: 2013-12-19 18:34     標題: 求救,這是怎么了?
[root@AY130811112859728246Z home]# sh install.sh
Setting up Install Process
No package screen available.
Nothing to do
Cannot find 'screen' command,install without screen(default yes)?
(Yes/No): y
Select Install
    1 apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    2 nginx + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    3 nginx + apache + php + mysql + zend + eAccelerator + pureftpd + phpmyadmin
    4 install all service
    5 don't install is now
Please Input 1,2,3,4,5: 1
Select php version:
    1 php-5.2.17 (default)
    2 php-5.3.27
Please Input 1,2: 1
error: skipping http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm - transfer failed - Unknown or unexpected error
Retrieving http://pkgs.repoforge.org/rpmforge-release/rpmforge-release-0.5.3-1.el5.rf.x86_64.rpm
No package gcc-c++ available.
No package autoconf available.
No package libtool-ltdl-devel available.
No package gd-devel available.
No package freetype-devel available.
No package libxml2-devel available.
No package libjpeg-devel available.
No package libpng-devel available.
No package openssl-devel available.
No package curl-devel available.
No package patch available.
No package libmcrypt-devel available.
No package libmhash-devel available.
No package ncurses-devel available.
No package libcap-devel available.
No package sendmail available.
No package unzip available.
Nothing to do
19 Dec 18:04:35 ntpdate[1878]: the NTP socket is in use, exiting
setenforce: SELinux is disabled
installing mysql,this may take a few minutes,hold on plz...
configure in progress ...
Preparing...                ##################################################
rpmforge-release            ##################################################
Resolving Dependencies
--> Running transaction check
---> Package libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf set to be updated
--> Processing Dependency: libmcrypt = 2.5.7-1.2.el5.rf for package: libmcrypt-devel
--> Processing Dependency: libmcrypt.so.4()(64bit) for package: libmcrypt-devel
---> Package mhash-devel.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Processing Dependency: mhash = 0.9.9-1.el5.rf for package: mhash-devel
--> Processing Dependency: libmhash.so.2()(64bit) for package: mhash-devel
---> Package libmcrypt.x86_64 0:2.5.7-1.2.el5.rf set to be updated
---> Package mhash.x86_64 0:0.9.9-1.el5.rf set to be updated
--> Finished Dependency Resolution
Dependencies Resolved
Package               Arch         Version                Repository      Size
Installing:
libmcrypt-devel       x86_64       2.5.7-1.2.el5.rf       rpmforge       112 k
mhash-devel           x86_64       0.9.9-1.el5.rf         rpmforge        19 k
Installing for dependencies:
libmcrypt             x86_64       2.5.7-1.2.el5.rf       rpmforge       182 k
mhash                 x86_64       0.9.9-1.el5.rf         rpmforge       161 k
Transaction Summary
Install      4 Package(s)
Update       0 Package(s)
Remove       0 Package(s)
Total download size: 475 k
Downloading Packages:
Total                                            68 kB/s | 475 kB     00:06
Running rpm_check_debug
Running Transaction Test
Finished Transaction Test
Transaction Test Succeeded
Running Transaction
  Installing     : mhash                                                    1/4
  Installing     : libmcrypt                                                2/4
  Installing     : mhash-devel                                              3/4
  Installing     : libmcrypt-devel                                          4/4
Installed:
  libmcrypt-devel.x86_64 0:2.5.7-1.2.el5.rf mhash-devel.x86_64 0:0.9.9-1.el5.rf
Dependency Installed:
  libmcrypt.x86_64 0:2.5.7-1.2.el5.rf       mhash.x86_64 0:0.9.9-1.el5.rf
Complete!
19 Dec 18:05:36 ntpdate[8149]: the NTP socket is in use, exiting
用的阿里云服務器 ,安裝N次了,每次都是這樣。求高手幫忙。
作者: 270330940    時間: 2013-12-19 19:56
求高手幫個忙知道,謝謝。
作者: admin    時間: 2013-12-20 10:41
什么版本的系統(tǒng)?
看下logs目錄下的日志的最后面內(nèi)容
