[教程] 關(guān)于mysql升級(jí)到5.5報(bào)錯(cuò)問題
升級(jí)命令wget http://down.wdlinux.cn/in/mysql_up55.sh
sh mysql_up55.sh
安裝日志錯(cuò)誤部分
Shutting down MySQL. SUCCESS!
scripts/mysql_install_db.sh: line 325: @HOSTNAME@: command not found
WARNING: The host '' could not be looked up with resolveip.
This probably means that your libc libraries are not 100 % compatible
with this binary MySQL version. The MySQL daemon, mysqld, should work
normally with the exception that host name resolving will not work.
This means that you should use IP addresses instead of hostnames
when specifying MySQL privileges !
Installing MySQL system tables...
OK
Filling help tables...
OK
To start mysqld at boot time you have to copy
support-files/mysql.server to the right place for your system
PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
To do so, start the server, then issue the following commands:
/www/wdlinux/mysql/bin/mysqladmin -u root password 'new-password'
/www/wdlinux/mysql/bin/mysqladmin -u root -h  password 'new-password'
Alternatively you can run:
/www/wdlinux/mysql/bin/mysql_secure_installation
which will also give you the option of removing the test
databases and anonymous user created by default.  This is
strongly recommended for production servers.
See the manual for more instructions.
You can start the MySQL daemon with:
cd /www/wdlinux/mysql ; /www/wdlinux/mysql/bin/mysqld_safe &
You can test the MySQL daemon with mysql-test-run.pl
cd /www/wdlinux/mysql/mysql-test ; perl mysql-test-run.pl
Please report any problems with the /www/wdlinux/mysql/scripts/mysqlbug script!
ERROR! MySQL server PID file could not be found!
Starting MySQL. ERROR! The server quit without updating PID file (/www/wdlinux/mysql-5.5.27/data/localhost.localdomain.pid).
Running..., Please Wait...
err
mysql update is OK
錯(cuò)誤情況
http://www.gps-cemuyi.cn/bbs/viewthread.php?tid=5137
安裝完后提示
重啟mysql時(shí)提示,后臺(tái)登陸不了。
解決辦法
vi /www/wdlinux/init.d/mysqld
修改46 47行的目錄為安裝目錄與數(shù)據(jù)庫目錄
哈哈
感謝,升級(jí)成功了
OK
拖拖的表示不錯(cuò)...
這個(gè)證明了,有效!。。。
非常非常感謝
我給了667 要找一下是不是,啟動(dòng)時(shí)用了哪個(gè)用戶。 他沒有權(quán)限運(yùn)行。
好東西值
我要收藏的噠。 為什么沒有收藏到!!
感謝分享,我的問題解決了
my.cnf  還需要777權(quán)限才能啟動(dòng)
謝謝不錯(cuò)謝謝不錯(cuò)謝謝不錯(cuò)謝謝不錯(cuò)
RE: MYSQL5.5+php5.4+zend guard升級(jí)方法
謝謝不錯(cuò)支持支持,找了半天終于搞定
我來頂貼,只為讓更多的人看到這個(gè)好貼。感謝樓主
就是用此方法解決,謝謝。
