2 做過哪些操作或改動設置等
沒金幣啊,這么下載
謝謝謝謝謝謝謝謝
來看
這個可以了解一下
沒有金幣怎么辦
PHP
看看!!!!!!!!
看看看看看看
試一下看看
回復一個,下載文件
你好啊啊啊
看看啊啊啊
回復 1# 8l8
升級mysql5.6.28出現(xiàn)這個錯誤,是什么緣故。。。
   -- Looking for asprintf-- Looking for asprintf - found
-- Check size of pthread_t
-- Check size of pthread_t - done
-- Using cmake version 2.8.12.2
-- Not building NDB
-- Performing Test HAVE_PEERCRED
-- Performing Test HAVE_PEERCRED - Success
-- Library mysqlclient depends on OSLIBS -lpthread;m;rt;dl
-- Googlemock was not found. gtest-based unit tests will be disabled. You can run cmake . -DENABLE_DOWNLOADS=1 to automatically download and build required components from source.
-- If you are inside a firewall, you may need to use an http proxy: export http_proxy=http://example.com:80
-- Library mysqlserver depends on OSLIBS -lpthread;m;rt;crypt;dl
-- CMAKE_BUILD_TYPE: RelWithDebInfo
-- COMPILE_DEFINITIONS: HAVE_CONFIG_H
-- CMAKE_C_FLAGS:  -Wall -Wextra -Wformat-security -Wvla -Wwrite-strings -Wdeclaration-after-statement
-- CMAKE_CXX_FLAGS:  -Wall -Wextra -Wformat-security -Wvla -Woverloaded-virtual -Wno-unused-parameter
-- CMAKE_C_FLAGS_RELWITHDEBINFO: -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF
-- CMAKE_CXX_FLAGS_RELWITHDEBINFO: -O3 -g -fabi-version=2 -fno-omit-frame-pointer -fno-strict-aliasing -DDBUG_OFF
-- Configuring incomplete, errors occurred!
See also "/root/mysql-5.6.28/CMakeFiles/CMakeOutput.log".
See also "/root/mysql-5.6.28/CMakeFiles/CMakeError.log".
configure err
試一下
看看行不行
謝謝分享謝謝分享謝謝分享
再下載一次試試。。。
sh ./zendopcache_ins.sh
