[求助] 全新安裝出錯(cuò) 請(qǐng)問什么原因
make[1]: *** [httpd] Error 1
make[1]: Leaving directory `/root/lanmp/httpd-2.2.22'
make: *** [all-recursive] Error 1
----Install Error: apache make err -----------
我也出現(xiàn)同樣的錯(cuò)誤,不知道你們?cè)趺唇鉀Q的我
Centos5.8 32位,郁悶的要死!。。。。。。。!
怎么會(huì)有這樣的錯(cuò)誤提示,你的系統(tǒng)操作過什么或升級(jí)過什么?
回復(fù) 6# admin
[root@localhost ~]# yum install -y libxml2-devel
There was a problem importing one of the Python modules
required to run yum. The error leading to this problem was:
   libxml2.so.2: cannot open shared object file: No such file or directory
Please install a package which provides this module, or
verify that the module is installed correctly.
It's possible that the above module doesn't match the
current version of Python, which is:
2.4.3 (#1, Sep 21 2011, 20:06:00)
[GCC 4.1.2 20080704 (Red Hat 4.1.2-51)]
If you cannot solve this problem yourself, please go to
the yum faq at:
  http://wiki.linux.duke.edu/YumFaq
回復(fù) 4# admin
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... (cached) yes
checking for uint32_t... (cached) yes
checking for strtoll... (cached) yes
checking for atoll... (cached) yes
checking libxml2 install dir... no
checking for xml2-config path... (cached) /usr/local/bin/xml2-config
configure: error: xml2-config not found. Please check your libxml2 installation.
----Install Error: wdphp configure err -----------
這樣看不出問題原因
Centos 5.7
全新安裝lanmp v2.2.1,詳細(xì)按照官方教程安裝,最后一步出現(xiàn)下面的錯(cuò)誤
