[求助] 奇怪了,我這臺(tái)機(jī)器的MYSQL就是弄不好,2.4也不行
每次安裝的時(shí)候PUTTY都會(huì)有一聲“嘟”的錯(cuò)誤,都是在安裝到這里的時(shí)候
Making install in win
make[1]: Entering directory `/root/lanmp/mysql-5.1.61/win'
make[2]: Entering directory `/root/lanmp/mysql-5.1.61/win'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/root/lanmp/mysql-5.1.61/win'
make[1]: Leaving directory `/root/lanmp/mysql-5.1.61/win'
chown: cannot access `/www/wdlinux/mysql/var': No such file or directory
Starting MySQL.Manager of pid-file quit without updating fi[FAILED]
error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
pcre installing...
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
那個(gè)[FAILED]似乎就是錯(cuò)誤,安裝完畢有3行連續(xù)的ERROR 2002,然后service mysqld start提示的是
Starting Mysql.Manager of pid-file quit without updating fi[FAILED]
就不行了,昨晚弄了一夜,2.2,2.3都試了,然后給客服留了言,讓他幫我把這個(gè)VPS初始化一下,今早看到出了2.4,而且VPS又初始化了,應(yīng)該沒(méi)問(wèn)題了,結(jié)果還是這樣,仔細(xì)一看出錯(cuò)的內(nèi)容,似乎是chown出錯(cuò),于是我創(chuàng)建了/www/wdlinux/mysql/var這個(gè)目錄,然后chown mysql:mysql 這個(gè)目錄
再service mysqld start,問(wèn)題依舊
現(xiàn)在默認(rèn)頁(yè)面可以打開(kāi),就是8080提示無(wú)法連接mysql,請(qǐng)檢查mysql是否已啟動(dòng)及用戶密碼是否設(shè)置正確!:
求老大幫忙。。。。
什么系統(tǒng)?怎么會(huì)沒(méi)這個(gè)文件?
可以了  /etc/hosts根本這文件就不存在,夠坑爹的
另外老大說(shuō)的2.4新出的rpm安裝5分鐘就完事應(yīng)該怎么弄啊,我這還是編譯的,將近一個(gè)小時(shí)
[root@a2515 bin]# mysql_install_db
Neither host 'a2515' nor 'localhost' could be looked up with
/www/wdlinux/mysql-5.1.61/bin/resolveip
Please configure the 'hostname' command to return a correct
hostname.
If you want to solve this at a later stage, restart this script
with the --force option
[root@a2515 bin]#
這是啥意思。。。。
/www/wdlinux/mysql/bin/mysql_install_db
運(yùn)行下這個(gè)
沒(méi)有。。。。。只有一個(gè)err文件。。我帖出來(lái)。。老大救命。。。
[root@a2515 var]# vi a2515.err
120619 12:06:21 mysqld_safe Starting mysqld daemon with databases from /www/wdlinux/mysql-5.1.61/var
/www/wdlinux/mysql-5.1.61/libexec/mysqld: Table 'mysql.plugin' doesn't exist
120619 12:06:21 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
120619 12:06:21 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.host' doesn't exist
120619 12:06:21 mysqld_safe mysqld from pid file /www/wdlinux/mysql-5.1.61/var/a2515.pid ended
如果沒(méi)有,就是在安裝創(chuàng)建mysql數(shù)據(jù)庫(kù)時(shí)沒(méi)成功
你看下/www/wdlinux/msyql/var目錄下有沒(méi)內(nèi)容?
正常情況下,這里會(huì)有
mysql
test
兩個(gè)目錄
以及一兩個(gè)文件
我在這家又開(kāi)了一個(gè)試用的VPS,一樣的系統(tǒng),居然沒(méi)問(wèn)題。。。。難道我這臺(tái)被詛咒了?
CentOS 5.7 32位標(biāo)準(zhǔn)版  啥都沒(méi)
什么系統(tǒng),什么版本,系統(tǒng)里面有沒(méi)有自帶的服務(wù)器相關(guān)的軟件。
QQ群:147711167
