[教程] configure: error: no acceptable C compiler found in $PATH
在 安裝一鍵包或編譯軟件時,比較經(jīng)常會有如下的提示
checking for egrep... grep -E
checking for cc... no
checking for gcc... no
See `config.log' for more details.
注意看紅色字體文字
意思是,沒有安裝GCC等編譯器,因為Linux里編譯軟件,都要用到GCC,所以這個是必須的,否則,是無法安裝的
這種情況,一般是在安裝系統(tǒng)時最小安裝或選擇安裝時沒有選擇編譯環(huán)境等原因
那怎么辦呢,可以用yum來安裝
yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel
執(zhí)行完上面這個就可以了
但是,確定上面有執(zhí)行成功,有些情況是,上面這個也執(zhí)行不成功的,那樣還是仍然會有問題,上面這個執(zhí)行不成功,一般是DNS的問題
回復(fù) 1# admin
836001996
admin 發(fā)表于 2012-9-9 10:06
    提示安裝pdo_mysql 成功了  ...服務(wù)也重啟了... php.ini里也自動加入了
  1. zend_extension_ts=/www/wdlinux/Zend/lib/ZendExtensionManager_TS.soextension=pdo_mysql.so
但是在phpinfo里依然沒有  pdo_mysql  ...這是啥情況...
  1.   --> Missing Dependency: kernel-headers >= 2.2.1 is needed by package glibc-headers-2.5-81.el5_8.7.x86_64 (updates)
  2. glibc-headers-2.5-81.el5_8.7.x86_64 from updates has depsolving problems
  3.   --> Missing Dependency: kernel-headers is needed by package glibc-headers-2.5-81.el5_8.7.x86_64 (updates)
  4. Error: Missing Dependency: kernel-headers >= 2.2.1 is needed by package glibc-headers-2.5-81.el5_8.7.x86_64 (updates)
  5. Error: Missing Dependency: kernel-headers is needed by package glibc-headers-2.5-81.el5_8.7.x86_64 (updates)
  6. You could try using --skip-broken to work around the problem
  7. You could try running: package-cleanup --problems
  8.                         package-cleanup --dupes
  9.                         rpm -Va --nofiles --nodigest
  10. The program package-cleanup is found in the yum-utils package.
執(zhí)行后提示這樣的錯誤...咋辦
