[求助] wdcp 安裝不成功
1.服務(wù)器在美國
2,系統(tǒng)是centos 6 x64
3,RPM包安裝,第二步的時候。出現(xiàn)
4,人要瘋了,F(xiàn)在。在線等,高手解決。
這個是下載問題,lanmp_wdcp-2-5.el6.x86_64.rpm,沒下來吧~~
qw
回復(fù) 2# l9ong
    還是一樣的問題。安裝不成功。openvz 的安裝wdcp 是直接RPM包安裝嗎?還是有其他操作
把下面內(nèi)容復(fù)制到sh文件里,執(zhí)行就可以了lanmp_wdcp_ins.sh:
  1. #!/bin/bash
  2. #
  3. # WDlinux Control Panel,lamp,lnmp system install scripts
  4. # Created by wdlinux QQ:12571192
  5. # Url:http://www.gps-cemuyi.cn
  6. # Last Updated 2012.06.23
  7. #
  8. if [[ $1 == "uninstall" ]];then
  9.         echo "starting backup data..."
  10.         mkdir -p /www/backup
  11.         service mysqld stop
  12.         service nginxd stop
  13.         service httpd stop
  14.         service wdapache stop
  15.         service pureftpd stop
  16.         tar zcvf /www/backup/mysqldatdbk.tar.gz /www/wdlinux/mysql/var
  17.         tar zcvf /www/backup/ngconfbk.tar.gz /www/wdlinux/nginx/conf
  18.         tar zcvf /www/backup/apconfbk.tar.gz /www/wdlinux/apache/conf
  19.         rpm -e lanmp_wdcp --nodeps
  20.         rm -fr /www/wdlinux
  21.         echo
  22.         echo "        lanmp,wdcp remove is OK"
  23.         echo
  24.         exit 0
  25. fi
  26. echo "Turn off selinux..."
  27. setenforce 0
  28. sed -i 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config
  29. sed -i 's/^exclude=/#exclude=/g' /etc/yum.conf
  30. yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel sudo bzip2 iptables sendmail iptables unzip
  31. #echo "Check the network..."
  32. #ping -c 2 113.105.167.1
  33. #if [[ $? != 0 ]];then
  34. #        echo
  35. #        echo "network err"
  36. #        exit 1
  37. #fi
  38. ping -c 3 dl.wdlinux.cn
  39. if [[ $? == 2 ]];then
  40.         echo
  41.         echo "dns error"
  42.         exit 1
  43. fi
  44. if [[ ! -d /www/wdlinux ]];then
  45.         echo
  46.         echo "rpm remove..."
  47.         rpm -e php --nodeps
  48.         rpm -e httpd --nodeps
  49.         rpm -e mysql-server --nodeps
  50.         rpm -e mysql --nodeps
  51. fi
  52. echo "yum update..."
  53. yum install -y make autoconf sudo wget libtool-ltdl-devel gd-devel freetype-devel libxml2-devel libjpeg-devel libpng-devel openssl-devel curl-devel patch libmcrypt-devel libmhash-devel ncurses-devel iptables
  54. arch=i386
  55. Aurl="http://dl.wdlinux.cn:5180/rpms"
  56. if [[ `uname -m` == "x86_64" ]];then
  57.         arch="x86_64"
  58. fi
  59. function in_finsh {
  60.         echo
  61.         echo "          configuration ,lamp or lnmp,wdcp install is finshed"
  62.         echo "          visit http://ip"
  63.         echo "          wdcp visit http://ip:8080"
  64.         echo "          more infomation please visit http://www.gps-cemuyi.cn"
  65.         echo
  66. }
  67. function in_check {
  68.         if [[ $1 == 1 ]];then
  69.                 echo
  70.                 echo "============  $2 install error  ============="
  71.                 echo
  72.                 exit 1
  73.         else
  74.                 echo
  75.                 echo "============  $2 install OK  =============="
  76.                 echo
  77.                 echo
  78.         fi
  79. }
  80. grep -E 'wdOS 1|5\.' /etc/redhat-release > /dev/null 2>&1
  81. v1=$?
  82. grep -E 'wdOS 2|6\.' /etc/redhat-release > /dev/null 2>&1
  83. v2=$?
  84. if [ $v1 == 0 ];then
  85.         RF="lanmp_wdcp-2-5.$arch.rpm";
  86. elif [ $v2 == 0 ];then
  87.         RF="lanmp_wdcp-2-5.el6.$arch.rpm";
  88.         if [ $arch == "x86_64" ];then
  89.                 wget -c http://dl.wdlinux.cn:5180/soft/rpmforge-release-0.5.2-2.el6.rf.x86_64.rpm
  90.                 rpm -ivh rpmforge-release-0.5.2-2.el6.rf.x86_64.rpm
  91.         else
  92.                 wget -c http://dl.wdlinux.cn:5180/soft/rpmforge-release-0.5.2-2.el6.rf.i686.rpm
  93.                 rpm -ivh rpmforge-release-0.5.2-2.el6.rf.i686.rpm
  94.         fi
  95.         yum install -y mhash-devel libmcrypt-devel
  96. else
  97.         echo
  98.         echo "The current system does not support"
  99.         echo
  100.         exit
  101. fi
  102. wget -c http://dl.wdlinux.cn:5180/rpms/$RF
  103. rpm -ivh $RF --nodeps
  104. I_F=$?
  105. if [ $I_F == 0 ];then
  106.         echo
  107. fi
  108. in_check $I_F lanmp_wdcp
  109. rm -f wdcp_v*
  110. wget -c http://down.wdlinux.cn/down/wdcp_v2.5.tar.gz > /dev/null 2>&1
  111. tar zxvf wdcp_v2.5.tar.gz -C / > /dev/null 2>&1
  112. in_finsh
qw
