[求助] 阿里云服務器,用的WDlinux一鍵安裝包,現(xiàn)在遇到個問題
阿里云服務器,用的WDlinux一鍵安裝包,現(xiàn)在遇到個問題:一個程序是PHP5.3版本,一個程序是PHP5.4以上版本,請問一下程序設計師,咱們的一鍵安裝包有沒有可以在阿里云多PHP版本運行環(huán)境。謝謝
山高人為峰
本帖最后由 fgfeng 于 2017-9-25 09:05 編輯
checking if your cpp allows macro usage in include lines... yes
checking for IMAP support... no
checking for IMAP Kerberos support... no
checking for IMAP SSL support... no
checking for InterBase support... no
checking whether to enable internationalization support... yes
checking for icu-config... no
checking for location of ICU headers and libraries... not found
configure: error: Unable to detect ICU prefix or no failed. Please verify ICU install prefix and make sure icu-config works.
make: *** 沒有指明目標并且找不到 makefile。 停止。
x86_64
CentOS release 6.7 (Final)
----Install Error: 5.4.45 -----------
安裝錯誤解決:
yum install -y icu libicu libicu-devel
已經(jīng)找到安裝失敗的原因,是應為云鎖的原因,請執(zhí)行命令后重新安裝PHP即可安裝成功,本人測試成功(非常感謝:1013477247 )
echo y|/usr/local/yunsuo_agent/uninstall
[PEAR] Archive_Tar    - installed: 1.3.12
[PEAR] Console_Getopt - installed: 1.3.1
[PEAR] Structures_Graph- installed: 1.0.4
[PEAR] XML_Util       - installed: 1.2.3
[PEAR] PEAR           - installed: 1.9.5
Wrote PEAR system config file at: /www/wdlinux/phps/54/etc/pear.conf
You may want to add: /www/wdlinux/phps/54/lib/php to your php.ini include_path
//src/php-5.4.45/build/shtool install -c ext/phar/phar.phar /www/wdlinux/phps/54/bin
ln -s -f /www/wdlinux/phps/54/bin/phar.phar /www/wdlinux/phps/54/bin/phar
Installing PDO headers:          /www/wdlinux/phps/54/include/php/ext/pdo/
--2017-09-25 08:45:36--  http://www.gps-cemuyi.cn/conf/php/php-fpm.conf
Resolving www.gps-cemuyi.cn... 119.146.223.143
Connecting to www.gps-cemuyi.cn|119.146.223.143|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 476 [application/octet-stream]
Saving to: “/www/wdlinux/phps/54/etc/php-fpm.conf”
100%[======================================>] 476         --.-K/s   in 0s
2017-09-25 08:45:36 (114 MB/s) - “/www/wdlinux/phps/54/etc/php-fpm.conf” saved [476/476]
5.4.45 install complete
      configurations, phps install is complete
      visit http://ip:8080
      more infomation please visit http://www.gps-cemuyi.cn/bbs/
山高人為峰
引用的 admin 貼子
v3升級到v3.2后,多PHP版本共存的安裝方法
自v3.2開始,wdcp支持多PHP版本共存共用和切換,可根據(jù)需求靈活選擇和使用
從v3.0/3.1升級的用戶,還需要再安裝下多版本的PHP環(huán)境,才可完全正常使用和切換
安裝方法如下:
sh phps.sh
(共支持7個版本的PHP,如5.2.17/5.3.29/5.4.45/5.5.38/5.6.30/7.0.18/7.1.4)
默認安裝使用版本,可以針對或選擇性安裝某個版本,如
sh phps.sh 7.1.4
即可安裝7.1.4
引用的Admin 貼子
多版本PHP的手動啟動|停止|重起
如:5.5
/www/wdlinux/phps/55/bin/php-fpm start
/www/wdlinux/phps/55/bin/php-fpm stop
/www/wdlinux/phps/55/bin/php-fpm restart
如是其它版本,把55替換為相應版本即可
如無特別求,可不必全部安裝或啟動,因為啟動多一個,就會占資源多一份
已知問題
CentOS 7.X系列系統(tǒng),不再支持php-5.2/5.3的老版本PHP,可考慮使用CentOS 6.X
山高人為峰
