[求助] wdcp 怎么手動安裝模塊?
本帖最后由 liqz2009 于 2013-9-8 19:44 編輯
*  symfony requirements check  *
php.ini used by PHP: /www/wdlinux/apache_php-5.2.17/etc/php.ini
** Mandatory requirements **
  OK        PHP version is at least 5.2.4 (5.2.17p1)
** Optional checks **
  OK        PDO is installed
  OK        PDO has some drivers installed: sqlite, sqlite2
  OK        PHP-XML module is installed
[[WARNING]] XSL module is installed: FAILED
            *** Install and enable the XSL module (recommended for Propel) ***
  OK        The token_get_all() function is available
  OK        The mb_strlen() function is available
  OK        The iconv() function is available
  OK        The utf8_decode() is available
  OK        The posix_isatty() is available
[[WARNING]] A PHP accelerator is installed: FAILED
            *** Install a PHP accelerator like APC (highly recommended) ***
[[WARNING]] php.ini has short_open_tag set to off: FAILED
            *** Set it to off in php.ini ***
[[WARNING]] php.ini has magic_quotes_gpc set to off: FAILED
  OK        php.ini has register_globals set to off
  OK        php.ini has session.auto_start set to off
  OK        PHP version is not 5.2.9
PHP version is not 5.2.9安裝wdcp之后,運行check_configure.php有幾個模塊沒有安裝,通過yum安裝成功,但是重啟后,網(wǎng)頁檢測提示依舊。是不是yum安裝到了原來的httpd中了?怎么才能安裝wdcp管理的網(wǎng)站里邊呢?在線急等,請幫助。
看多少遍了,也沒找到相關的,您給個鏈接哦!
您這回復也太牛逼了
多看簽名
沒有管理員嗎?
apc可以編譯到指定目錄wdlinuxe,xsl怎么弄呢?
有人知道怎么弄嗎?
