[求助] lanmp_wdcp_v2.4快速安裝RPM包安裝后嚴(yán)重問題
512MB VPS, 裝的centos 6 32bit, 系統(tǒng)純凈,未安裝其它。安裝RPM包后,最后提示安裝成功,然后卡死,無(wú)法PING,不能SSH,
可以通過VPS提供商的面板可看到狀態(tài)和操作,證明VPS主機(jī)應(yīng)該沒問題,但無(wú)法通過putty來(lái)SSH。
附安裝最后部分代碼:
  1. --2013-01-10 06:27:29--  http://dl.wdlinux.cn:5180/rpms/lanmp_wdcp-2-5.el6.i386.rpm
  2. Resolving dl.wdlinux.cn... 61.146.178.5
  3. Connecting to dl.wdlinux.cn|61.146.178.5|:5180... connected.
  4. HTTP request sent, awaiting response... 200 OK
  5. Length: 90710939 (87M) [text/plain]
  6. Saving to: “l(fā)anmp_wdcp-2-5.el6.i386.rpm”
  7. 100%[======================================>] 90,710,939  6.77M/s   in 14s
  8. 2013-01-10 06:27:46 (6.08 MB/s) - “l(fā)anmp_wdcp-2-5.el6.i386.rpm” saved [90710939/90710939]
  9. Preparing...                ########################################### [100%]
  10.    1:lanmp_wdcp             ########################################### [100%]
  11. Installing MySQL system tables...
  12. OK
  13. Filling help tables...
  14. OK
  15. To start mysqld at boot time you have to copy
  16. support-files/mysql.server to the right place for your system
  17. PLEASE REMEMBER TO SET A PASSWORD FOR THE MySQL root USER !
  18. To do so, start the server, then issue the following commands:
  19. /www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root password 'new-password'
  20. /www/wdlinux/mysql-5.1.63/bin/mysqladmin -u root -h danrun password 'new-password'
  21. Alternatively you can run:
  22. /www/wdlinux/mysql-5.1.63/bin/mysql_secure_installation
  23. which will also give you the option of removing the test
  24. databases and anonymous user created by default.  This is
  25. strongly recommended for production servers.
  26. See the manual for more instructions.
  27. You can start the MySQL daemon with:
  28. cd /www/wdlinux/mysql-5.1.63 ; /www/wdlinux/mysql-5.1.63/bin/mysqld_safe &
  29. You can test the MySQL daemon with mysql-test-run.pl
  30. cd /www/wdlinux/mysql-5.1.63/mysql-test ; perl mysql-test-run.pl
  31. Please report any problems with the /www/wdlinux/mysql-5.1.63/bin/mysqlbug script!
  32. chown: invalid user: `mysql.mysql'
  33. Starting MySQL. ERROR! Manager of pid-file quit without updating file.
  34. /www/wdlinux/mysql/bin/mysqladmin: connect to server at 'localhost' failed
  35. error: 'Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)'
  36. Check that mysqld is running and that the socket: '/tmp/mysql.sock' exists!
  37. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  38. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  39. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  40. ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
  41. Starting httpd: [  OK  ]
  42. Starting nginx: [  OK  ]
  43. Starting httpd: [  OK  ]
  44. Starting pure-config.pl: Running: /usr/sbin/pure-ftpd --daemonize -S21 -A -c50 -B -C8 -D -E -fftp -H -I15 -L10000:8 -m4 -s -U133:022 -u100 -k99 -Z -lunix -p20000:20500 -lmysql:/www/wdlinux/etc/pureftpd-mysql.conf
  45. ============  lanmp_wdcp install OK  ==============
重新安裝試試
本帖最后由 dan 于 2013-1-10 13:14 編輯
因?yàn)闆]辦法ssh, 只能通過VPS商的控制面板重新安裝一次centos6 32bit系統(tǒng)了, 安裝完后, SSH恢復(fù)正常連接.
重試了一次快速RPM安裝, 狀況一樣, 到最后提示安裝完成后, SSH就自動(dòng)斷開連接, 再也連不上去, VPS的IP加上8080, 也不能顯示W(wǎng)DCP的頁(yè)面, 但實(shí)際上VPS主機(jī)并沒問題. 只是不能SSH, 不能PING.
請(qǐng)老大檢查一下是否這個(gè)快速安裝包有改動(dòng)過SSH的端口? 還是防火墻之類的?
應(yīng)該不會(huì)改變或關(guān)閉SSH端口的,
試試用一鍵安裝包通過源碼編譯安裝吧
http://www.gps-cemuyi.cn/bbs/thread-2523-1-1.html
好, 等下再試試編譯安裝
回復(fù) 3# dan
  不會(huì)修改SSH端口的,不過會(huì)調(diào)整iptables的規(guī)則,如果在安裝之前修改過SSH的端口,也就是非默認(rèn)的22端口,則可能會(huì)有問題
回復(fù)  dan
  不會(huì)修改SSH端口的,不過會(huì)調(diào)整iptables的規(guī)則,如果在安裝之前修改過SSH的端口,也就是非默 ...
admin 發(fā)表于 2013-1-10 16:09
請(qǐng)問是調(diào)整了iptables的哪些規(guī)則?因?yàn)樵嚵藥状味际亲詈缶妥詣?dòng)斷開SSH,好生奇怪。下午試了用編譯安裝,很正常,難道是RPM不適合用在我這個(gè)VPS?
PS:VPS是米國(guó)的bluevm, 512MB內(nèi)存,openvz,裝的是centOS6.2 32bit
可能和openvz有關(guān)
