[BUG反饋] wdcp v3 安裝出錯
Starting httpd (via systemctl):  Job for httpd.service failed because the control process exited with error code. See "systemctl status httpd.service" and "journalctl -xe" for details.
                                                           [FAILED]
Starting nginxd (via systemctl):  Job for nginxd.service failed because the control process exited with error code. See "systemctl status nginxd.service" and "journalctl -xe" for details.
                                                           [FAILED]
安裝之后可以訪問 ip:8080 但是ip 無法訪問
重啟一次服務(wù)器之后 ip, ip:8080 都無法訪問了
                                                           [FAILED]
Starting nginxd (via systemctl):  Warning: nginxd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
                                                           [FAILED]
用這個命令systemctl status httpd.service
紅色字上一行,顯示類似bad user www的話,這樣解決
groupadd www
useradd -g www www
然后service httpd restart,就可以了。
什么系統(tǒng)
服務(wù)未啟動
請問你們解決了嗎?請解決了的私信我好嗎?我也碰到這個問題……
裝的時候看看版本的系統(tǒng)要求,我撞過一次槍口.
