[教程] WDCP自動(dòng)將主機(jī)上的文件上傳到百度網(wǎng)盤中
本帖最后由 Miker 于 2018-8-7 13:10 編輯
bpcs_uploader,利用bpcs_uploader你可以自動(dòng)將VPS主機(jī)上的文件上傳到百度網(wǎng)盤中,同時(shí)也可以從百度網(wǎng)盤中下載文件到VPS主機(jī)上,讓你的文件安全地“住”在百度云中。
百度云空間容量大,且有了百度這個(gè)靠山,日后也不必?fù)?dān)心網(wǎng)盤關(guān)門走人,隨著眾多國(guó)內(nèi)網(wǎng)盤開始投放大量的廣告到網(wǎng)盤下載頁(yè)面(典型的有華為網(wǎng)盤、下載賺錢網(wǎng)盤),百度網(wǎng)盤清爽的風(fēng)格就顯得難能可貴了。將文件上傳到百度云中就可以方便其它用戶下載
1.安裝wdcp
sh lanmp_wdcp_ins.sh
2.下載bpcs_uploader上傳腳本
https://github.com/oott123/bpcs_uploader/tarball/master
chmod +x bpcs_uploader.php執(zhí)行權(quán)限
3.查看php路徑
/www/wdlinux/nginx_php-5.2.17/bin/php –v
bpcs_uploader.php第一行修改成
#!/www/wdlinux/nginx_php-5.2.17/bin/php -ddisable_functions -d safe_mode=Off
  • [root@VM_166_159_centos oott123-bpcs_uploader-3a75324]# ./bpcs_uploader.php quickinit
  • ===========================Baidu PCS Uploader===========================
  • Usage: ./bpcs_uploader.php init|quickinit|quota
  • Usage: ./bpcs_uploader.php upload|download path_local path_remote
  • Usage: ./bpcs_uploader.php delete path_remote
  • Usage: ./bpcs_uploader.php uploadbig path_local path_remote [slice_size(default:1073741824)]        [temp_dir(def:/tmp/)]
  • Usage: ./bpcs_uploader.php fetch path_remote path_to_fetch
  • Uploader initialization will be begin. If you have already configured the uploader before, y        our old settings will be overwritten.
  • Continue? [y/N] y
  •   % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
  •                                  Dload  Upload   Total   Spent    Left  Speed
  • 171   263    0   263    0    80    671    204 --:--:-- --:--:-- --:--:--  3210
  • Launch your favorite web browser and visit https://openapi.baidu.com/device
  • Input 2a24n8dv as the user code if asked.
  • After granting access to the application, come back here and press Enter to continue.
  • 244   101    0   101    0   143    531    753 --:--:-- --:--:-- --:--:--     0
  • OAuth error authorization_pending : User has not yet completed the authorization
  • Authentication failed. Please check the error message and try again.
  • Continue? [y/N] y
  • 244   101    0   101    0   143    546    773 --:--:-- --:--:-- --:--:--     0
  • Continue? [y/N] y
  • 180   397    0   397    0   143   2162    778 --:--:-- --:--:-- --:--:--  5772
  •   0    66    0    66    0     0    220      0 --:--:-- --:--:-- --:--:--   366
  • Access Granted. Your Storage Status: 105.95G/2063.00G (5.14%)
  • Enjoy!
以上為快速初始化代碼,輸入授權(quán)碼網(wǎng)址:https://openapi.baidu.com/device
  • 然后打開瀏覽器訪問 https://openapi.baidu.com/device ,在“請(qǐng)輸入設(shè)備上顯示的用戶授權(quán)碼:”文本框中輸入上面顯示的授權(quán)碼,并點(diǎn)擊繼續(xù)。 看到網(wǎng)頁(yè)上顯示“請(qǐng)返回設(shè)備繼續(xù)操作!”后,返回ssh上按下回車后,即完成了初始化配置。
  • 重新分配
    • [root@VM_166_159_centos oott123-bpcs_uploader-3a75324]# ./bpcs_uploader.php init
    • Uploader initialization will be begin. If you have already configured the uploader before, your old settings will b        e overwritten.
    • Continue? [y/N] y
    • Please enter your PSC App API Key. You can get this key by visiting http://developer.baidu.com/dev#/create
    • If you have already created an app, you can visit http://developer.baidu.com/console#/app and get it in your app's        info.
    • If you don't want to bother creating an app, you can press Enter to use the demo API Key.
    • Doing so (without your own API Key/Secret) will cause the access-token to expire every 30 days, and you'll have to
    • re-initialize when it expires.
    • App API KEY [uFBSHEwWE6DD94SQx9z77vgG] :uFBSHEwWE6DD94SQx9z77vgG
    • App API Key has been set to uFBSHEwWE6DD94SQx9z77vgG .
    • Demo key detected. Using default API Secret.
    • Demo key detected. Using default app name.
    • 171   263    0   263    0    80   1355    412 --:--:-- --:--:-- --:--:--  3452
    • Input axmhkper as the user code if asked.
    • 179   395    0   395    0   143   2010    727 --:--:-- --:--:-- --:--:--  5250
    •   0    67    0    67    0     0    294      0 --:--:-- --:--:-- --:--:--   690
4.我們測(cè)試上傳文件
付費(fèi)解決 QQ15365637
