/root/php-5.3.29/ext/iconv/iconv.c: 在函數(shù)‘zm_startup_miconv’中:
/root/php-5.3.29/ext/iconv/iconv ...
sun302775121 發(fā)表于 2016-1-25 15:11
我和你的錯(cuò)誤一樣
回復(fù) 1# admin
360截圖20160225172415896.jpg 幫我看一下,為什么升能不成功
只剩下如下內(nèi)容
tar: php-5.3.29.tar.gz: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
php_up53.sh: line 18: cd: php-5.3.29: No such file or directory
make: *** No rule to make target `clean'.  Stop.
php_up53.sh: line 21: ./configure: No such file or directory
configure err
tar: 歸檔文件中異常的 EOF
tar: 歸檔文件中異常的 EOF
make: *** 沒(méi)有規(guī)則可以創(chuàng)建目標(biāo)“clean”。 停止。
php_up53.sh: line 21: ./configure: 沒(méi)有那個(gè)文件或目錄
configure err
[root@MyServer ~]#
安裝提示到這些就停止了,有問(wèn)題嗎
管理員,求解。照著你給出的方法,php up腳本升級(jí)到一半報(bào)這個(gè)錯(cuò)誤。
報(bào)告老大php.ini出錯(cuò)了喔~
有沒(méi)有更高版本的啊??
怎么升級(jí)php到5.4以上?
為什么安裝WDCP面板后的php版本那么低啊
升級(jí)失敗了,最后的結(jié)果是這樣的,怎么解決哦
checking size of long... (cached) 8
checking size of long long... (cached) 8
checking for iconv support... yes
checking for libiconv in -liconv... yes
checking if iconv is glibc's... yes
checking if iconv supports errno... yes
checking if your cpp allows macro usage in include lines... yes
checking for IMAP support... no
checking for IMAP Kerberos support... no
checking for IMAP SSL support... no
checking for InterBase support... no
checking whether to enable internationalization support... no
checking whether to enable JavaScript Object Serialization support... yes
checking for ANSI C header files... (cached) yes
checking for LDAP support... no
checking for LDAP Cyrus SASL support... no
checking whether to enable multibyte string support... yes
checking whether to enable multibyte regex support... yes
checking whether to check multibyte regex backtrack... yes
checking for external libmbfl... no
checking for external oniguruma... no
checking for variable length prototypes and stdarg.h... yes
checking for strings.h... yes
checking for unistd.h... (cached) yes
checking for sys/time.h... (cached) yes
checking for sys/times.h... yes
checking for stdarg.h... (cached) yes
checking size of short... (cached) 2
checking for working const... yes
checking whether time.h and sys/time.h may both be included... yes
checking for working alloca.h... (cached) yes
checking for alloca... (cached) yes
checking for 8-bit clean memcmp... yes
checking for mcrypt support... yes
configure: error: mcrypt.h not found. Please reinstall libmcrypt.
configure err
[root@ebs-44955 ~]#
馬克一下。。。。
現(xiàn)在才發(fā)現(xiàn) DZ插件要支持5.3 ,可是看你們升級(jí)都出問(wèn)題了。  不敢升級(jí)了:Q
回復(fù)只為收藏,php5.2完美升級(jí)到5.3。
php5.3升級(jí)腳本 碼一個(gè)
升級(jí)腳本無(wú)法下載 403:'(
