gcc: Internal error: Killed (program cc1)
Please submit a full bug report.
See <http://bugzilla.redhat.com/bugzilla> for instructions.
make: *** [ext/fileinfo/libmagic/apprentice.lo] Error 1
make err
You have new mail in /var/spool/mail/root
請(qǐng)教該怎么辦?
升級(jí)報(bào)錯(cuò)。。!失。。!報(bào)錯(cuò)如下:
  1. /root/php-5.3.17/ext/iconv/iconv.c: In function ‘zm_startup_miconv’:
  2. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯(cuò)誤:‘_libiconv_version’ 未聲明 (在此函數(shù)內(nèi)第一次使用)
  3. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯(cuò)誤:(即使在一個(gè)函數(shù)內(nèi)多次出現(xiàn),每個(gè)未聲明的標(biāo)識(shí)符在其
  4. /root/php-5.3.17/ext/iconv/iconv.c:254: 錯(cuò)誤:所在的函數(shù)內(nèi)只報(bào)告一次。)
  5. make: *** [ext/iconv/iconv.lo] 錯(cuò)誤 1
  6. make err
請(qǐng)問老大,這個(gè)怎么解決?????
萬分感謝,阿門。。。!
云建站
要省錢,上匯誠(chéng):匯誠(chéng)網(wǎng)
升級(jí)不成功,阿里云EMC系統(tǒng)是CentOS 6.3 64位
老大給的三個(gè)升級(jí)都提示OK了,phpinfo查看也正常 E6@Q$RWPYIHNZ{X%KME@66S.jpg ,但是打開網(wǎng)站后臺(tái)時(shí)候就提示 Zend Guard Run-time support missing!
敢不敢用 PHP.NET 的源啊 ,用你自己的源速度慘不忍睹
http://cn2.php.net/get/php-5.3.17.tar.gz/from/a/mirror
一次性升級(jí)結(jié)束,很順利!
感謝樓主
升級(jí)以后提示
virtual memory exhausted: Cannot allocate memory
請(qǐng)問如何解決!
慢慢來
升級(jí)后,打開網(wǎng)站后臺(tái)提示
Zend Optimizer not installed
This file was encoded by the Zend Guard. In order to run it, please install the Zend Optimizer (available without charge), version 3.0.0 or later.
Seeing this message instead of the website you expected?
This means that this webserver is not configured correctly. In order to view this website properly, please contact the website's system administrator/webmaster with the following message:
The component "Zend Optimizer" is not installed on the Web Server and therefore cannot service encoded files. Please download and install the Zend Optimizer (available without charge) on the Web Server.
Note: Zend Technologies cannot resolve issues related to this message appearing on websites not belonging to Zend Technologies.
What is the Zend Optimizer?
The Zend Optimizer is one of the most popular PHP plugins for performance-improvement, and has been available without charge, since the early days of PHP 4. It improves performance by scanning PHP's intermediate code and passing it through multiple Optimization Passes to replace inefficient code patterns with more efficient code blocks. The replaced code blocks perform exactly the same operations as the original code, only faster.
In addition to improving performance, the Zend Optimizer also enables PHP to transparently load files encoded by the Zend Guard.
The Zend Optimizer is a free product available for download from Zend Technologies. Zend Technologies also developed the PHP scripting engine, known as the Zend Engine.
淘省錢網(wǎng)
不行啊,報(bào)錯(cuò)了
錯(cuò)誤代碼
centos 5.6 32位 128內(nèi)存   不知道跟內(nèi)存小有沒有關(guān)系
See <URL:http://bugzilla.redhat.com/bugzilla&gt; for instructions.
make: *** [ext/date/lib/parse_date.lo] Error 1
make err
這個(gè)東西超級(jí)贊!。
按照老大的提示,已經(jīng)成功升級(jí)!
————————————————打一個(gè)小小的廣告哈:
中國(guó)萬維網(wǎng)
CPU雙核內(nèi)存1.5G硬盤100G空間帶寬5M獨(dú)享IP獨(dú)立1個(gè)機(jī)房北京多線機(jī)房 原價(jià)2200元,年底特價(jià)只需900元!
http://www.wanweiwang.cn/services/cloudhost/ttCloudServer.asp
wget: command not found.
提示問題。。
PHP 5.3.3 是嗎?
sh php_up53.sh
php-5.3.17/pear/install-pear.txt
php-5.3.17/pear/fetch.php
php-5.3.17/LICENSE
php-5.3.17/README.input_filter
make: *** No rule to make target `clean'.  Stop.
loading cache ./config.cache
checking for Cygwin environment... no
checking for mingw32 environment... no
checking for egrep... grep -E
checking for gcc... no
checking for cc... no
configure: error: no acceptable cc found in $PATH
configure err
[root@ZZ8800606062c29212 ~]#
請(qǐng)問如何處理的呢?
o
  1. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc  -Iext/dom/ -I/root/php-5.3.17/ext/dom/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/dom/userdatahandler.c -o ext/dom/userdatahandler.lo
  2. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc -I/root/php-5.3.17/ext/fileinfo/libmagic -Iext/fileinfo/ -I/root/php-5.3.17/ext/fileinfo/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/fileinfo/fileinfo.c -o ext/fileinfo/fileinfo.lo
  3. /bin/sh /root/php-5.3.17/libtool --silent --preserve-dup-deps --mode=compile gcc -I/root/php-5.3.17/ext/fileinfo/libmagic -Iext/fileinfo/ -I/root/php-5.3.17/ext/fileinfo/ -DPHP_ATOM_INC -I/root/php-5.3.17/include -I/root/php-5.3.17/main -I/root/php-5.3.17 -I/root/php-5.3.17/ext/date/lib -I/root/php-5.3.17/ext/ereg/regex -I/usr/include/libxml2 -I/usr/kerberos/include -I/usr/include/freetype2 -I/root/php-5.3.17/ext/mbstring/oniguruma -I/root/php-5.3.17/ext/mbstring/libmbfl -I/root/php-5.3.17/ext/mbstring/libmbfl/mbfl -I/www/wdlinux/mysql/include -I/root/php-5.3.17/ext/sqlite3/libsqlite -I/root/php-5.3.17/TSRM -I/root/php-5.3.17/Zend    -I/usr/include -g -O2 -fvisibility=hidden  -prefer-non-pic -c /root/php-5.3.17/ext/fileinfo/libmagic/apprentice.c -o ext/fileinfo/libmagic/apprentice.lo
  4. gcc: Internal error: Killed (program cc1)
  5. Please submit a full bug report.
  6. See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
  7. make: *** [ext/fileinfo/libmagic/apprentice.lo] Error 1
  8. make err
使用升級(jí)腳本后出錯(cuò)了,不過后臺(tái)和網(wǎng)站還打得開。就是沒有php沒升級(jí)成功。怎么灰事?
