關(guān)于DZ不支持高版本eaccelerator問(wèn)題的解決辦法
最近有用戶反應(yīng),在DZ中不支持高版本的eaccelerator,建議降級(jí)到低版本的 0.9.5.3
為方便使用,在這里列出降級(jí)的方法
wget -c http://bart.eaccelerator.net/source/0.9.5.3/eaccelerator-0.9.5.3.tar.bz2
tar jxvf eaccelerator-0.9.5.3.tar.bz2
cd  eaccelerator-0.9.5.3
./configure --enable-eaccelerator=shared --with-eaccelerator-shared-memory --with-php-config=/www/wdlinux/php/bin/php-config
make
make install
重起web服務(wù),如
service httpd restart
or
service nginxd restart
或直接使用自動(dòng)降級(jí)腳本,如下
wget http://www.gps-cemuyi.cn/in_scripts/eaccelerator0953
sh eaccelerator0953
歡迎轉(zhuǎn)載,但請(qǐng)保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/360
/root$ wget
/root$ wget http://www.gps-cemuyi.cn/in_scripts/eaccelerator0953
--2011-05-01 22:22:24--  http://www.gps-cemuyi.cn/in_scripts/eaccelerator0953
Resolving www.gps-cemuyi.cn... failed: Temporary failure in name resolution.
wget: unable to resolve host address `www.gps-cemuyi.cn'
DNS問(wèn)題
DNS問(wèn)題
/root$ wget -c
/root$ wget -c http://bart.eaccelerator.net/source/0.9.5.3/eaccelerator-0.9.5.3.tar.bz2
--2011-05-01 22:20:09--  http://bart.eaccelerator.net/source/0.9.5.3/eaccelerator-0.9.5.3.tar.bz2
Resolving bart.eaccelerator.net... failed: Temporary failure in name resolution.
wget: unable to resolve host address `bart.eaccelerator.net'
實(shí)在不懂,求指導(dǎo)
方法2的
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
make: *** No rule to make target `/home/bart/development/eaccelerator/branches/0.9.5/eaccelerator.c', needed by `eaccelerator.lo'.  Stop.
Stopping httpd:                                            [  OK  ]
Starting httpd:                                            [  OK  ]
方法1的
[root@MyVPS1099 eaccelerator-0.9.5.3]# ./configure --enable-eaccelerator=shared --with-eaccelerator-shared-memory --with-phpconfig=/www/wdlinux/php/bin/phpp-config
checking for gcc... no
checking for cc... no
checking for cl.exe... no
沒(méi)有安裝GCC編譯環(huán)境 yum install -y
yum install -y gcc gcc-c++ make autoconf libtool-ltdl-devel
編譯的參數(shù)不正確,應(yīng)該為: ./configure
加上了
加上了
