花了我一個小時安裝這個系統(tǒng)但是中途報錯了,不知道什么原因
checking for statvfs... yes
checking for std_syslog... no
checking for strcasecmp... yes
checking for strcoll... yes
checking for strdup... yes
checking for strerror... yes
checking for strftime... yes
checking for strnlen... yes
checking for strptime... yes
checking for strstr... yes
checking for strtok_r... yes
checking for symlink... yes
checking for tempnam... yes
checking for tzset... yes
checking for unlockpt... yes
checking for unsetenv... yes
checking for usleep... yes
checking for utime... yes
checking for vsnprintf... yes
checking for nanosleep... checking for nanosleep in -lrt... yes
yes
checking for getaddrinfo... yes
checking for strlcat... no
checking for strlcpy... no
checking for getopt... yes
checking whether utime accepts a null argument... yes
checking for working alloca.h... (cached) yes
checking for alloca... yes
checking for declared timezone... yes
checking for type of reentrant time-related functions... POSIX
checking for readdir_r... yes
checking for type of readdir_r... POSIX
checking for in_addr_t... yes
checking for crypt_r... no
General settings
checking whether to include gcov symbols... no
checking whether to include debugging symbols... no
checking layout of installed files... PHP
checking path to configuration file... /www/wdlinux/etc
checking where to scan for configuration files...
checking whether to enable safe mode by default... no
checking for safe mode exec dir... /usr/local/php/bin
checking whether to enable PHP's own SIGCHLD handler... no
checking whether to enable magic quotes by default... no
checking whether to explicitly link against libgcc... no
checking whether to enable short tags by default... yes
checking whether to enable dmalloc... no
checking whether to enable IPv6 support... yes
checking how big to make fd sets... using system default
Configuring extensions
checking size of long... (cached) 4
checking for int32_t... yes
checking for uint32_t... yes
checking for strtoll... yes
checking for atoll... yes
checking libxml2 install dir... /usr
checking for xml2-config path... /usr/bin/xml2-config
checking whether libxml build works... yes
checking for OpenSSL support... yes
checking for Kerberos support... no
checking for DSA_get_default_method in -lssl... yes
checking for pkg-config... /usr/bin/pkg-config
checking for PCRE support... yes
checking for ZLIB support... yes
checking if the location of ZLIB install directory is defined... no
checking for gzgets in -lz... yes
checking whether to enable bc style precision math functions... no
checking for BZip2 support... no
checking whether to enable calendar conversion support... no
checking whether to enable ctype functions... yes
checking for cURL support... yes
checking if we should use cURL for url streams... no
checking for cURL in default path... found in /usr
checking for cURL 7.10.5 or greater... libcurl 7.15.5
checking for SSL support in libcurl... yes
checking how to run the C preprocessor... gcc -E
checking for openssl support in libcurl... yes
checking for openssl/crypto.h... yes
checking for gnutls support in libcurl... no
checking for curl_easy_perform in -lcurl... yes
checking for curl_version_info in -lcurl... yes
checking for curl_easy_strerror in -lcurl... yes
checking for curl_multi_strerror in -lcurl... yes
checking for QDBM support... no
checking for GDBM support... no
checking for NDBM support... no
checking for Berkeley DB4 support... no
checking for Berkeley DB3 support... no
checking for Berkeley DB2 support... no
checking for DB1 support... no
checking for DBM support... no
checking for CDB support... no
checking for INI File support... no
checking for FlatFile support... no
checking whether to enable DBA interface... no
checking whether to enable dbase support... no
checking whether to enable DOM support... yes
checking for xml2-config path... (cached) /usr/bin/xml2-config
checking whether libxml build works... (cached) yes
checking whether to enable EXIF (metadata from images) support... no
checking for FrontBase SQL92 (fbsql) support... no
checking for FDF support... no
checking whether to enable input filter support... yes
checking pcre install prefix... no
checking whether to enable FTP support... yes
checking OpenSSL dir for FTP... no
checking for fabsf... yes
checking for floorf... yes
----Install Error: php configure err -----------
You have mail in /var/spool/mail/root
[root@GHVM48-R2-01 ~]#
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/529
錯誤已經(jīng)顯示在你面前了 configure: error:
錯誤已經(jīng)顯示在你面前了
系統(tǒng)是哪個版本?32 or 64?
[root@GHVM48-R2-01 /]# ls
[root@GHVM48-R2-01 /]# ls /
bin   dev  home  lost+found  misc  net  proc  sbin     srv  tftpboot  usr  www
boot  etc  lib   media       mnt   opt  root  selinux  sys  tmp       var
[root@GHVM48-R2-01 /]# getconf LONG_BIT
32
[root@GHVM48-R2-01 /]# ldd /sbin/mii-tool
        linux-gate.so.1 =>  (0x0075d000)
        libselinux.so.1 => /lib/libselinux.so.1 (0x00606000)
        libc.so.6 => /lib/libc.so.6 (0x00456000)
        libdl.so.2 => /lib/libdl.so.2 (0x005c7000)
        libsepol.so.1 => /lib/libsepol.so.1 (0x00620000)
        /lib/ld-linux.so.2 (0x00438000)
[root@GHVM48-R2-01 /]# cat /etc/issue
Red Hat Enterprise Linux Server release 5.4 (Tikanga)
Kernel \r on an \m
[root@GHVM48-R2-01 /]# cat /proc/version
Linux version 2.6.18-164.el5 (mockbuild@x86-002.build.bos.redhat.com) (gcc version 4.1.2 20080704 (Red Hat 4.1.2-46)) #1 SMP Tue Aug 18 15:51:54 EDT 2009
[root@GHVM48-R2-01 /]# uname -r
2.6.18-164.el5
yum沒有安裝到相應(yīng)的包和庫 1 更新yum源 2
1 更新yum源
2 手載下載源碼包編譯
3 重裝CentOS5.5/5.6
32位 red hat linux
32位 red hat linux
我曉得是哪個錯誤,但是不知道,怎么下手去調(diào)整呢
