軟件發(fā)布
warning: Creating default object from empty value in /www/web/w1/wdlinux_cn/old/modules/modules/taxonomy/taxonomy.pages.inc on line 33.
軟件發(fā)布
Varnish Cache 3.0.2 發(fā)布
Varnish是一款高性能的開源HTTP加速器,挪威最大的在線報紙 Verdens Gang (http://www.vg.no) 使用3臺Varnish代替了原來的12臺squid,性能居然比以前更好。
Varnish Cache 3.0.2 發(fā)布了,下載地址:
改進(jìn)內(nèi)容:
  • A crasher bug when requests were queued and the backend sent a response with Vary has been fixed
  • A crash when a too large synthetic response was produced has been fixed.
  • The ban lurker now properly sleeps the 1 second it is supposed to
  • Varnish now releases disk space properly if no -s argument is provided, and the default cache size is now 100MB instead of 50% of the available disk space
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/1458
Apache Tomcat 7.0.16 發(fā)布
Apache Tomcat 團(tuán)隊宣布Apache Tomcat 7.0.16 正式發(fā)布。
Apache Tomcat 7.0.16 包括bug修復(fù)和以下特性(相比7.0.14版本):
- AJP 連接器的NIO實現(xiàn)。
- 當(dāng)使用集群時,Servlet 3 異步進(jìn)程支持。
- 增加Ant任務(wù)的并行部署支持。
Apache Tomcat 7.0.16 完整變化日志:
http://tomcat.apache.org/tomcat-7.0-doc/changelog.html
該版本有4 zip binaries:
a generic one and three bundled with Tomcat native binaries for Windows operating systems running on different CPU architectures。
Apache Tomcat 7.0.16 下載:
http://tomcat.apache.org/download-70.cgi
Apache Tomcat 5.5.x 和 6.0.x 的遷移指南:
http://tomcat.apache.org/migration.html
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/779
Nginx 1.0.4 發(fā)布下載
Changes with nginx 1.0.4
    *) Change: now regular expressions case sensitivity in the "map" directive is given by prefixes "~" or "~*".
    *) Feature: now shared zones and caches use POSIX semaphores on Linux.
    *) Bugfix: "stalled" cache updating" alert.
    *) Bugfix: nginx could not be built --without-http_auth_basic_module; the bug had appeared in 1.0.3.
下載地址:
http://nginx.org/download/nginx-1.0.4.tar.gz
http://nginx.org/download/nginx-1.0.4.zip
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/728
MySQL 5.5 13 GA 發(fā)布下載
MySQL 5.5 發(fā)布第 13 個更新版本,下載地址:
http://dev.mysql.com/downloads/mysql/5.5.html
該版本主要是bug修復(fù),包括 Innodb 引擎以及分區(qū)和復(fù)制功能方面的問題,詳情請看 Change History
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/725
紅帽企業(yè) Linux 發(fā)布 5.7 Beta 版
Red Hat 剛剛發(fā)布了 RHEL 5.7 的Beta 版,這是 5.0 版本自 2007 發(fā)布以來的第 7 個更新版。
該版本包含大量企業(yè)管理、虛擬化性能和數(shù)據(jù)中心靈活性方面的增強,同時更新了驅(qū)動程序和內(nèi)核對 Intel、AMD、PowerPC 和 IBM 小型機(jī)的支持。
該版本同時還包含新的企業(yè)特性,包括 OpenSCAP 安裝報告、跨平臺開發(fā)工具以及新的訂閱管理。
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/713
phpMyAdmin 3.4.1/3.3.10.1發(fā)布
phpMyAdmin 3.4.1 是一個安全補丁版本以及修復(fù)了一些小bug,而 3.3.10.1 是一個純安全補丁版本。
具體的安全問題請看 http://www.phpmyadmin.net/home_page/security/
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/684
紅帽發(fā)布企業(yè) Linux 6.1 正式版
紅帽公司剛剛宣布了紅帽企業(yè)Linux 6.1 正式版發(fā)布。6.1 版本提升了系統(tǒng)的可靠性、伸縮性以及性能,支持最新的硬件,同時包含補丁和安全更新。
具體請看 http://www.redhat.com/rhel/server/whats_new/
可通過 Red Hat Network 下載
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/677
MySQL Cluster 7.1.13 GA 發(fā)布下載
MySQL Cluster 是 MySQL 適合于分布式計算環(huán)境的高實用、高冗余版本。它采用了NDB Cluster 存儲引擎,允許在1個 Cluster 中運行多個MySQL服務(wù)器。在MyQL 5.0及以上的二進(jìn)制版本中、以及與最新的Linux版本兼容的RPM中提供了該存儲引擎。(注意,要想獲得MySQL Cluster 的功能,必須安裝 mysql-server 和 mysql-max RPM)。
目前能夠運行MySQL Cluster 的操作系統(tǒng)有Windows、Linux、Mac OS X和Solaris(一些用戶通報成功地在FreeBSD上運行了MySQL Cluster ,但MySQL AB公司尚未正式支持該特性)。
MySQL Cluster 由一組計算機(jī)構(gòu)成,每臺計算機(jī)上均運行著多種進(jìn)程,包括MySQL服務(wù)器,NDB Cluster 的數(shù)據(jù)節(jié)點,管理服務(wù)器,以及(可能)專門的數(shù)據(jù)訪問程序。
下載地址:http://dev.mysql.com/downloads/cluster/7.1.html
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/660
支持win和Linux的系統(tǒng)克隆工具Clonezilla
Clonezilla 是一個很好的系統(tǒng)克隆工具,它可以說是吸取了 Norton Ghost 和 Partition Image 的優(yōu)點。即不僅支持對整個系統(tǒng)進(jìn)行克隆,而且也可以克隆單個的分區(qū),這種靈活性可能更能適應(yīng)備份者的需要。
Clonezilla 的功能:
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/657
Perl 5.14.0 發(fā)布下載
Perl 5.14.0 發(fā)布,這個版本的變化包括:支持 Unicode 6.0,更好的IPv6的支持,一些正則表達(dá)式的加強,性能改進(jìn)等等。
Perl是一種腳本語言。 最初的設(shè)計者為拉里·沃爾(Larry Wall),它於1987年12月18日發(fā)表。Perl借取了C、、awk、shell scripting 以及很多其他程式語言的特性。其中最重要的特性是他內(nèi)部集成了正則表達(dá)式的功能,以及巨大的第三方代碼庫 CPAN
詳細(xì)更新請看 http://search.cpan.org/~jesse/perl-5.14.0/pod/perldelta.pod
下載地址 http://search.cpan.org/CPAN/authors/id/J/JE/JESSE/perl-5.14.0.tar.gz
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/652
Scientific Linux 5.6 Beta2 發(fā)布下載
Scientific Linux是重新編譯的Red Hat Enterprise Linux,由費米國家加速器實驗室和歐洲核研究組織(CERN)共同開發(fā)。盡管它旨在與Red Hat Enterprise Linux完全兼容,它也提供了上游產(chǎn)品中未收入的額外軟件包,這當(dāng)中最值得一提的是各種文件系統(tǒng),包括Cluster Suite和Global File System(GFS)、FUSE、OpenAFS、Squashfs、Unionfs,以及對Intel無線固件的無線網(wǎng)絡(luò)支持、MadWiFi和 NDISwrapper、Sun Java及Java Development Kit(JDK)、輕量級的IceWM窗口管理器、面向統(tǒng)計計算的R語言環(huán)境,以及Alpine郵件客戶端。
發(fā)行說明:
http://listserv.fnal.gov/scripts/wa.exe?A2=ind1105&L=scientific-linux-devel&T=0&P=3051
http://ftp.scientificlinux.org/linux/scientific/5rolling/iso/i386/dvd/SL.56.051311.DVD.i386.disc1.iso
http://ftp1.scientificlinux.org/linux/scientific/5rolling/iso/x86_64/dvd/SL.56.051311.DVD.x86_64.disc1.iso
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/650
Java服務(wù)器Resin 4.0.18 發(fā)布及下載
改進(jìn)更新如下:
  • watchdog: set the LD_LIBRARY_PATH_64 variable on 64-bit systems (#4536)
  • access-log: rollover rescheduling of alarm was not reliable (#4540, rep by mros2stf)
  • ant-plugin: ant plugin has been moved to http://github.com/caucho/ant-plugin
  • resin-cli: added jmx-list, jmx-set, jmx-call commands
  • health: add OnStart, OnStop, OnRestart health predicates (#4257)
  • scheduled-task: forward with param was causing NPE (#4530, rep by kenjrwalker)
  • web-app: explicit web-app id="/" must override webapps/ROOT (#4531, rep by danielnuriyev)
  • session: distributed sessions now allows jdbc as a backup (#3929, rep by jkriesten)
  • servlet: fragment after/others ordering issues (#4523)
  • cdi: abstract decorators were not properly handled (#4406)
  • servlet: crlf escaping required for response headers because of rewrite-dispatch (#4525)
  • jpa: when jta-data-source is null and JPA fails to start, allow web-app to start w/o error (#4491)
  • watchdog: ResinMXBean now contains information about the last watchdog restart (#4257, rep by Tony Matson)
  • jsp/el: MethodExpr invocation was not applied property (#4515)
  • candi: @Produces on @Stateless with no interfaces (#4513)
  • config: add <data-source> element support (#4487)
  • jsp/el: BeanELResolver isValue/getValue mismatch (#4511, rep by Keith Fetterman)
  • servlet: web-fragment <name> can have an "id" attribute (#4484)
  • candi: ResinBeanContainer beans.xml @Alternatives issue (#4501)
  • candi: ResinBeanContainer JPA/beans.xml ordering issues (#4502)
  • session: add destroy-on-lru flag to session-config to call SessionListener.destroy on a LRU even when session is persisted (#4504)
  • servlet: CauchoRequestWrapper updates for MockHttpServletRequest compatibility (#4509)
  • jstl: c:set not properly returning XML for validation (#4492)
  • ejb: stateless generics on interface superclass (#4512, rep by andreaskaltenbach)
  • ejb: stateless generics on method argument (#4514)
  • config: <class-loader> has automatic priority (#4500)
  • watchdog: signal status reporting was showing exit 0 for signals (#4508)
  • hessian: send-collection-type should always send java.util types (#4489, rep by Keith Fetterman)
  • ioc: resin:message not properly initialized (#4496, rep by Keith Fetterman)
  • ioc: env-entry does not use EL - doc update (#4516, rep by mnsh)
  • ejb: ejb-ee jar with <entity> should be skipped w/o fatal error (#4503, rep by Rick Mann)
    下載 Resin 4.0.18
     http://www.caucho.com/download/
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/649
Nginx 1.0.0 正式版發(fā)布
經(jīng)過 9年的開發(fā),Nginx 終于迎來了1.0版本,可通過svn://svn.nginx.org 獲取源碼。Nginx 的第一個公開發(fā)布的版本 0.1.0 是在 2004年10月4日發(fā)布的。
根據(jù)W3Techs的報告顯示,全球前1百萬網(wǎng)站(alexa)中,使用Nginx的占據(jù)6.8%。在俄羅斯,排名靠前的網(wǎng)站將近一半使用Nginx。Netcraft 的最新報告 “2011年4月份的Web服務(wù)器調(diào)查報告” 顯示目前Nginx在排名百萬內(nèi)網(wǎng)站中,份額已經(jīng)達(dá) 6.52%
下載地址:http://www.nginx.org/en/download.html
改進(jìn)內(nèi)容:
Changes with nginx 1.0.0                                         12 Apr 2011
*) Bugfix: a cache manager might hog CPU after reload.
Thanks to Maxim Dounin.
*) Bugfix: an "image_filter crop" directive worked incorrectly coupled
with an "image_filter rotate 180" directive.
*) Bugfix: a "satisfy any" directive disabled custom 401 error page.
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/527
Linux From Scratch 6.8 發(fā)布
Linux From Scratch項目簡稱LFS,它提供必要的步驟,幫你一步一步地創(chuàng)建自己定制的Linux系統(tǒng)。關(guān)于為什么有人希望安裝一套LFS系統(tǒng),我們可以給出很 多的理由。人們問得最多的問題是,既然可以下載到一份成型的套件比如Debian或者Red Hat,為什么還要去爭論從頭開始手工安裝一份Linux系統(tǒng)呢?這是一個很合理的問題,我將問答你。LFS存在的最重要的原因就是教給人們一個 Linux系統(tǒng)其內(nèi)部是如何工作的。自己創(chuàng)建一份LFS系統(tǒng)將讓你了解到Linux工作的每個細(xì)節(jié),以及它們是如何彼此依賴和協(xié)同工作的。最重要的在于, 你可以按自己的喜好和需求定制它。
下載地址:http://www.linuxfromscratch.org/lfs/download.html
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/292
MySQL 5.1.56 GA 發(fā)布和下載
HANGES內(nèi)容 http://dev.mysql.com/doc/refman/5.1/en/news-5-1-56.html
MySQL 5.1.56 GA下載
http://dev.mysql.com/downloads/mysql/5.1.html
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/291
高性能web服務(wù)器器軟件Nginx 0.8.53 發(fā)布和下載
Nginx(發(fā)音同 engine x)是一款輕量級的Web 服務(wù)器/反向代理服務(wù)器及電子郵件(IMAP/POP3)代理服務(wù)器,并在一個BSD-like 協(xié)議下發(fā)行.
改進(jìn)內(nèi)容:
*) Feature: now the "error_page" directive allows to change a status code in a redirect.
*) Feature: the "gzip_disable" directive supports special "degradation" mask.
*) Bugfix: a socket leak might occurred if file AIO was used.
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/nginx-0.8.53
入侵檢測系統(tǒng)Snort 2.9.0 發(fā)布和下載
Snort是美國Sourcefire公司開發(fā)的發(fā)布在GPL v2下的IDS(Intrusion Detection System)軟件
Snort有 三種工作模式:嗅探器、數(shù)據(jù)包記錄器、網(wǎng)絡(luò)入侵檢測系統(tǒng)模式。嗅探器模式僅僅是從網(wǎng)絡(luò)上讀取數(shù)據(jù)包并作為連續(xù)不斷的流顯示在終端上。數(shù)據(jù)包記錄器模式把數(shù) 據(jù)包記錄到硬盤上。網(wǎng)路入侵檢測模式分析網(wǎng)絡(luò)數(shù)據(jù)流以匹配用戶定義的一些規(guī)則,并根據(jù)檢測結(jié)果采取一定的動作。網(wǎng)絡(luò)入侵檢測系統(tǒng)模式是最復(fù)雜的,而且是可 配置的。
Snort可以用來監(jiān)測各種數(shù)據(jù)包如端口掃描等之外,還提供了以XML形式或數(shù)據(jù)庫形式記錄日志的各種插件。
該版本包含眾多的改進(jìn),包括功能豐富的IPS模式,性能的提升等等。
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Snort-2.9.0
企業(yè)級監(jiān)控系統(tǒng)Nagios 3.2.3 發(fā)布和下載
Nagios是一個監(jiān)視系統(tǒng)運行狀態(tài)和網(wǎng)絡(luò)信息的監(jiān)視系統(tǒng)。Nagios能監(jiān)視所指定的本地或遠(yuǎn)程主機(jī)以及服務(wù),同時提供異常通知功能等
Nagios可運行在Linux/Unix平臺之上,同時提供一個可選的基于瀏覽器的WEB界面以方便系統(tǒng)管理人員查看網(wǎng)絡(luò)狀態(tài),各種系統(tǒng)問題,以及日志等等。
Changes:
1. 修復(fù)了無法禁用所有活動的主機(jī)和服務(wù)的問題;
2. 代碼清理;
3. 修復(fù)了記錄代碼格式的bug
下載 Nagios 3.2.3
http://www.nagios.org/download/
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Nagios-3.2.3
GNU編譯器GCC 4.4.5 發(fā)布
GCCGNU Compiler Collection,GNU編譯器套裝),是一套由 GNU 開發(fā)的編程語言編譯器。它是一套以 GPLLGPL 許可證所發(fā)行的自由軟件,也是 GNU計劃 的關(guān)鍵部分,亦是自由的 類Unix 及蘋果計算機(jī) Mac OS X 操作系統(tǒng)的標(biāo)準(zhǔn)編譯器。GCC(特別是其中的C語言編譯器)也常被認(rèn)為是跨平臺編譯器的事實標(biāo)準(zhǔn)。
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/GCC-4.4.5
phpMyFAQ 2.6.9 發(fā)布
phpMyFAQ是一個多語言,完全數(shù)據(jù)庫驅(qū)動的FAQ系統(tǒng)。它支持多種 數(shù)據(jù)庫來存儲所有數(shù)據(jù),需要PHP4.1或更高的版本來訪問些數(shù)據(jù)。 phpMyFAQ還提供一個帶有WYSIWYG編輯器的內(nèi)容管理系統(tǒng),一個圖片管理器,靈活的多用戶支持,一個新聞系統(tǒng),用戶跟蹤,一個模板系統(tǒng),PDF 支持,一個備份系統(tǒng)和一個易于使用的安裝腳本。
該版本修復(fù)了一個潛在的XSS漏洞,對后臺管理界面進(jìn)行了小改進(jìn),修復(fù)了嵌入 Google 分析代碼的bug。
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/phpMyFAQ-2.6.9
Opsview 3.9.0 發(fā)布,企業(yè)監(jiān)控系統(tǒng)
Opsview 是一個企業(yè)級的網(wǎng)絡(luò)、服務(wù)器和應(yīng)用程序監(jiān)控工具,設(shè)計為可伸縮、靈活和易用的。可跟一些常用的監(jiān)控系統(tǒng)做集成,例如 Nagios Core、Nagvis、Net-SNMP 和 RRDTool 等。監(jiān)控服務(wù)運行于 Linux 和 Solaris 10 上,可監(jiān)控各種系統(tǒng)的服務(wù)器,包括 Windows。
changelog:
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Opsview-3.9.0
高性能web伺服器Nginx 0.8.52 發(fā)布與下載
昨天才剛剛發(fā)布的 Nginx 0.8.51 穩(wěn)定版,今天就宣布了 0.8.51 不穩(wěn)定,來了 0.8.52 版,該版本修復(fù)了一個嚴(yán)重的bug,該bug僅在 0.8.51 版本中存在:
nginx used SSL mode for a listen socket if any listen option was set
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Nginx-0.8.52
mysql數(shù)據(jù)庫分支Percona Server 5.1.50-rel11.4 發(fā)布
Percona 為 MySQL 數(shù)據(jù)庫服務(wù)器進(jìn)行了改進(jìn),在功能和性能上較 MySQL 有著很顯著的提升。該版本提升了在高負(fù)載情況下的 InnoDB 的性能、為 DBA 提供一些非常有用的性能診斷工具;另外有更多的參數(shù)和命令來控制服務(wù)器行為。
Percona Server 只包含 MySQL 的服務(wù)器版,并沒有提供相應(yīng)對 MySQL 的 Connector 和 GUI 工具進(jìn)行改進(jìn)
二進(jìn)制包下載地址:website.
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/node/80
高性能web服務(wù)器 Nginx 0.8.51 穩(wěn)定版發(fā)布和下載
Nginx(發(fā)音同 engine x)是一款輕量級的Web 服務(wù)器/反向代理服務(wù)器及電子郵件(IMAP/POP3)代理服務(wù)器,并在一個BSD-like 協(xié)議下發(fā)行。由俄羅斯的程序設(shè)計師Igor Sysoev所開發(fā),最初供俄國大型的入口網(wǎng)站及搜尋引擎Rambler(俄文:Рамблер)使用。  其特點是占有內(nèi)存少,并發(fā)能力強,事實上nginx的并發(fā)能力確實在同類型的網(wǎng)頁伺服器中表現(xiàn)較好.目前中國大陸使用nginx網(wǎng)站用戶有:新浪、網(wǎng)易、 騰訊,另外知名的微網(wǎng)志Plurk也使用nginx。
從該版本開始,Nginx 0.8.x 分支已經(jīng)是穩(wěn)定版本狀態(tài)。
Nginx 0.8.x 最大的改進(jìn)包括:
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Nginx-0.8.51
Squid 3.1.8 發(fā)布,Web緩存服務(wù)器/反向代理服務(wù)
Squid cache(簡稱為Squid)是一個流行的自由軟件(GNU通用公共許可證)的代理服務(wù)器和Web緩存服務(wù)器。Squid有廣泛的用途,從作為網(wǎng)頁服務(wù) 器的前置cache服務(wù)器緩存相關(guān)請求來提高Web服務(wù)器的速度,到為一組人共享網(wǎng)絡(luò)資源而緩存萬維網(wǎng),域名系統(tǒng)和其他網(wǎng)絡(luò)搜索,到通過過濾流量幫助網(wǎng)絡(luò) 安全,到局域網(wǎng)通過代理上網(wǎng)。Squid主要設(shè)計用于在Unix一類系統(tǒng)運行。
新版本對版本命名進(jìn)行了改進(jìn),改進(jìn)了最小的 squid.conf 配置樣本;
內(nèi)置對 IPv6 的支持;
錯誤頁面支持本地化;
實現(xiàn)了連接牽制(NTLM 認(rèn)證);
新增 QoS 流量控制支持;
增加 SSL bump ;
新增 eCAP 適配器模塊支持;
ICAP bypass and retry enhancements were made.
ICY streaming protocol support was added
下載最新版 Squid 服務(wù)器
歡迎轉(zhuǎn)載,但請保留此信息
本文連接:http://www.gps-cemuyi.cn/old/Squid-3.1.8
同步內(nèi)容
